That kind of braking will give you massive fade pretty quickly, but without cahones like space hoppers it’s hard to avoid. I could never figure out what causes rakes to behave like they have a massive air bubble then feel okay again 10 minutes later.
one theory is that unless it’s very fresh, dot can hold a lot of moisture and this starts to evaporate as your brakes heat up. One way to check is to pull a vacuum in a syringe sample of warm, used fluid and see if it evolves bubbles.
I don’t reckon flying does your brakes any favours – mine always tended to benefit from a bleed afterwards.
Checked your brake fluid reservoir levels?
