http://www.flickr.com/photos/65163466@N03/5934218985/in/photostream/
[img]
http://www.flickr.com/photos/65163466@N03/5934792676/in/photostream/
•A set of Hope Mini Disk Brakes (Both No.3 Callipers)
•Two Standard Hope Rotors (203mm and 160mm)
•One Set of Superstar Kevlar Pads (Used once)
This Disk brake set has been well used however very well looked after. The Reservoir caps of both Master Cylinders have been replaced with Hope anodised blue ones (£7.15 each). The front disk brake is in full working order and has been freshly bled. The Calliper has recently had its original pistons replaced with phenolic ones (£4 each) and has had a full new set of seals(£4). The rear brake however does not work and needs a service before being used. Once the rear brake has been fixed this brake set will return to being extremely powerful and reliable as when they were new.
Looking for around £70?
