Success!! I nearly did not bother to, but I tried your suggestion of swaping the bearings over. It worked! With the previous ‘top’ bearing swapped into the bottom/crown cup, it fitted perfectly, with only a very slight gap (less than 0.5mm? I can live with that!) resulting. The top race is a seal tight fit. It looks like the race that moved from top to crown was very slightly wrong size. Using digital calipers to measure, this race is very slightly too thick/high.
As a purchased (matching?) pair of bearings from Hope, I’m surprised they do not perfectly match exactly, but thankfully my lower/crown cup is slightly more roomy to accomodate.
My steering has never felt smoother and better :o)))
Greenbikerider.
