Viewing 13 posts - 1 through 13 (of 13 total)
  • Hope Freehub
  • randomuk
    Hello
    Need a new freehub
    Not 100% but think my current hub is a Hope Pro, will the Pro 2 Freehub fit my hub?
    cyclistm
    That’s a pro 2.. Pro 2evo will not work without replacing all the internals
    cyclistm
    Actually doesn’t look like it needs replacing though
    mikewsmith
    The evo has a different axle and bearing size but hope have some good exploded diagrams
    randomuk
    Smashing cheers, I can stil get hold of a Pro2 freehub
    The end is rounded off, the 11t cog is just spinning on any significant pedal pressure.
    randomuk
    Is there any benefit from going with the EVo and changing the internals over?
    cyclistm
    Not really. Think the evo has slightly less drag but the conversion for a new axle, bearings and end caps won’t be cheap
    randomuk
    Cheers 🙂
    smatkins1
    How on earth did you manage that?
    andyl
    chainwhip on the 11T when removing?
    tony07
    Have a free hub here for sale if you want. Usual cassette marks. Email in profile
    docrobster
    Actually in your situation I would upgrade the internals to evo spec at the same time.
    The cost of upgrading from old pro 2 to evo is mainly the new freehub and unless the bearings are brand new they will need replacing at some point, so you’re just left with the cost of the axle.
    The advantage of evo of old pro 2 is ease of adaptability eg to go bolt through its just new end caps instead of swapping the axle, and if you ever want to use an xd driver for sram 11 speed you need evo internals for that.
    My 8 1/2 year old pro 2 bodies both cracked at the flanges recently and hope sold me new hub bodies for £15 front £35 rear so no reason not to keep these hubs going as long as you can.
    cyclistm
    Fair point doc, also evo spares seem a little easier to find too
The topic ‘Hope Freehub’ is closed to new replies.
