Looking at getting a rear Evo 12mm hub, are the axle kits all you need or do you have to replace the bearings still when changing the axle to 12mm?
Also, 12mm seems to be bolt thru only (I would would prefer bolt up liek the 10mm) so I take it a seperate 135x12mm axle is required.
