I offered to fix a mates brand new Hope E4’s so he can get out today. They’re on a new bike, been ridden maximum ten times. Yesterday the lever lost all pressure and was pulling right to the bar.
I’m bleeding them with a tube and bottle at the nipple end. Fluid in at the lever end, pump and squirt etc… All normal. The first bit of fluid was very bubbly. Pushed a load of new fluid through and the lever builds pressure as expected.
Then, if I wiggle the lever there’s a rush of bubbles in the reservoir from underneath the metal plate. This keeps happening. It’s all new fluid in there now and I can feel pressure at the lever, then it gives way and the reservoir fills with bubbles.
Could the lever be sucking air in from anywhere? All fittings are tight. It’s in a work stand with the lever at the highest point and all that.
Just wondering, should I persevere with it, or whip it off and have him send it back?
Cheers.
