Can someone measure for me as I have a problem with a set of my hopes 🙁 the width of the different hope rotors for the M4s both new and older
I need to know the width of a
standard m4 rotor
Floating m4 rotor
Saw 180mm m4 rotor
Saw 183mm m4 rotor
Saw 180mm floating m4 rotor
Saw 183mm floating m4 rotor
I popped into evans yesterday to try and find out, I asked the chap if he had any older style m4 rotors which he said he didnt so i could compare, Then said he'd pop in the back and measure them up (which i think he was comparing the newer m4 and m6 (mine) widths)
I have a funny feeling they are narrower than mine as the lever throw on this set of hopes is a lot less than my other set i had with older stle rotors, both of mine have very slight drag, using hope pads and all the pistons are free
Front is a hope hb and the rear is an XT (evans lad said this was my problem) however i havent had it before on these hubs
