Viewing 7 posts - 1 through 7 (of 7 total)
  • Hope braided hose, jeeesssuss
  • easygirl
    How do you cut that stuff and get the brass collar on again
    **** hell
    nonk
    cut it as clean as you can then get it as round as you can then shave the plastic of the leading edge with a knife (get an adult to help with this) but to be fair it’s still a right fek on.
    singlespeedstu
    If you could go back in time you could strip the plastic coating off the hose. Undo the locking collar, slide the olive up the hose to where you want it. Then you could cut the hose that you no longer need off.
    This way you don’t have to struggle trying to get the olive over the **** hose that keeps **** fraying. 🙂
    Or if you have some of the yellow plastic blocks that come with shimano brakes. Use the cutout in them to clamp the braiding down again.
    Stevelol
    It’s a pain but possible believe me! Get a screwdriver and open the olive up a little, also make sure there are no metal strands fraying out on the hose, check out this guide: steveukmtb.wordpress.com/hope-braided-hydraulic-brake-hose-assembly/
    easygirl
    Singlespeedstu
    I had just worked your method out
    Seems obvious now, but t oo late however
    orangeboy
    I’ve always used some good cable cutters for cutting the pipe. As long
    As they are sharp you will get a nice clean cut.
    Knipex are the best I’ve found so far
    crftom
    I’ve always used park cable cutters never had a problem
The topic ‘Hope braided hose, jeeesssuss’ is closed to new replies.
