Arggghhhhh, help needed. So I’ve put the bottom bracket in the 68mm she’ll, 2 spaces on drive side, 1 on non drive side. I’ve got the truvativ conversion in non drive side bearings, all good, BUT wh n I tighten the cups up and then put axle through, there’s not much axle sticking out, I think it’s enough. So I tighten the crank arm on and within a few turns of hex key the crank seems to squash the bearings so very difficult to turn cranks. It’s no way that the arm is tight though as it’s got a wobble, I just don’t understand what the hell is wrong. Have I put spaces in wrong side, will that make a difference?? I need the spaces as the tub in middle won’t fit in without them. I even removed the tube and still seem to have the sameness issue? It’s pissing me off to put it mildly!! HELP!!!
