Evening all,
Recently fitted a Hope Press Fit Bottom Bracket (PF46 73-30mm / Steel Bearings / For 73mm Full Width).
Fitted on to a Specialized Camber Evo. Fitting went well with the Hope tool but the non-drive side bearing felt notchy. I thought it may loosen up and have ridden about 100 miles on it and in the meantime called Hope.
Hope reckoned either the bearing or the frame was outside tolerance and offered to check the bearing if i returned it. Anyway, I just dismantled it all and the bearing had nearly siezed. I’ve cleaned and regreased but it is reluctant to turn.
It seems my options are:
– Remove and refit (requires some whacking with a drift and potentially knackering the bearing).
– Remove and replace (won’t help if the frame is wonky).
– Remove and buy the version with the external cups (another 80 quids).
– Forget about it and replace when it bleeds ball bearings everywhere (risk wearing the crank spindle and getting stranded on the trail).
Or has anyone got any pearls of wisdom?
Cheers!
P.S i should add that on fitting the bearing in question took quite a lot of turns of the Hope tool to get in. It never quite felt like it had seated correctly but i can’t see how it could be wonky as the tool has a flat face.
