Viewing 12 posts - 1 through 12 (of 12 total)
  • hope bb bearings?
  • jonnyrockymountain
    Rather than buying a pair for £30 hope ones
    Anyone got a link to some just as good but cheaper?
    Thrustyjust
    As far as I know, they are a specific made for Hope, as they run direct on the axle, rather than use a plastic shim to axle. I just bought one, which was faulty on mine and is a 2 min job to swop it out.
    Junkyard
    kaesae on ebay still do them??/
    K tech or something or other
    BigJohn
    I just bought a few sets of bearings from KaTec Bikes
    I was surprised when Kaesae’s name came up on the confirmation. But they seem to be good bearings and well priced. They arrived quickly and most amazingly, because I bought 3 sets he also refunded about £5 postage to my Paypal account without being asked. Top man!
    Scapegoat
    Just browsed KaTec site and can’t find BB bearings specified…. is it just me?
    ir_bandito
    Kaesae doesn’t have the Hope specific ones, only 25mm id with a spacer.
    Best deal I’ve found was a bulk-purchase from UKBikestore, I think I ordered 10 bearings at £13 each.
    mrmonkfinger
    IIRC KaTeC’s for hope are regular sized bearings, with an adaptogizmo.
    Not that that is a particular problem, just mentioning it.
    The hope ones can have slightly larger balls as a result of the custom size = slightly longer life. Worth the extra? No idea.
    fozzybear
    get some hope ones from UKBikestore or return them to hope and ask for new ones to be fitted and use a cheap Shimano BB during the swap.
    Fantombiker
    These bearings are quite hard to get hold of….I have a few sets of quality bearings for the Hope Bottom Brackets. Brand new, stainless steel etc etc for £10 each posted, The Hope ones are £16 each I think. Can send photo….cheers
    djen83
    Just take the bearing size (ID = 24mm, OD = 37mm and width = 7mm)to a firm that made them – 2 min google job for bearing + location. They are all over the place, they’ll be peanuts. Then get the ‘top hat’ seals from UKBikeStore for a quid each if you have lost or destroyed the old ones.
    Job done!
    Dave
    ir_bandito
    Go on then, find someone, anyone, who makes a 24mm id, 37mm OD, 7mm thick bearing.
    djen83
    I did, and have a good contact to get them again next time I need them… hence the reason for adding my previous post to the discussion. Just trying to be helpful.
The topic ‘hope bb bearings?’ is closed to new replies.
