Viewing 8 posts - 1 through 8 (of 8 total)
  • Hope 180 183 Fitment:\ Drunken purchase..
  • godzilla
    Right, while i was drunk the other night i ordered a hope floating disc 180mm, disc arrived today and it dawns on me that the disc on my bike is a 183mm:( im running tech m4’s with a B mount, is the 180 going to be ok or should i re-order (sober) a 183?
    STATO
    just buy a different mount.
    godzilla
    I would rather sell the disc and buy another one the right size, when looking at the edge of the disc (183) it comes out further than the pad contact area buy a mm or so buy its touch n go is its enough..
    crofts2007
    shim out the b adaptor to caliper by 1mm?
    crofts2007
    re-read, shim is wrong way, thought disk was too big!
    STATO
    If all your pad is on the rotor you will be fine, if your pad overlaps the rotor you risk bottoming out pad against pad and also reducing the braking/pad area.
    godzilla
    When i look at the disc there is around 1mm of unused surface on the outside, so its actually got more purchase.
    dhrider
    I would say get the correct size of rotor to be safe!
The topic ‘Hope 180 183 Fitment:\ Drunken purchase..’ is closed to new replies.
