Will your forks have clearance? Std 29er ones won’t.
I’m working on the basis of cutting near the crown & installing inserts to increase axle width to 135mm & build the front wheel onto a rear hub, so this should give me clearance.
On the bottom bracket, again I was thinking of cutting away from frame & increasing to 100mm width again with insert, could then either get 100mm BB or even more make shift get a HT2 crankset & cut & shut that to suit the BB width – or is that stretching the bounds of metalurgic possibilities ? Could manage 1x but would prefer 2x if I can.
