Viewing 14 posts - 1 through 14 (of 14 total)
  • Hollow-tech II seized drive side
  • ajt123
    Hi, in a bit of a situation – drive side crank and axle won’t come out.
    Have taken off the NDS crank, axle wouldn’t come through, tapped with a big spanner with several layers of oily ray to soften the blow.
    No joy, so took out the NDS cup – this released it a bit and the spindle will pull through right to the end, but no further.
    Its almost like the end of the spindle is catching on the drive-side bearings.
    Any suggestions?
    Paranoid that I have ovalized the end of the NDS spindle. Seems unlikely.
    ajt123
    Just checked – spindle not ovalized – could easily put the NDS cut back over the end.
    Internal plastic space is detached – have now removed – not sure if this is a good, or bad sign.
    scaredypants
    check the axle. as long as that’s not scored, you’re laughing.
    need new bb though, I assume
    (they always stick a bit when pulling through – I wouldn’t worry)
    ajt123
    Hmmmn, doesn’t look scored at all. Just won’t pull through.
    wiggles
    hit it
    bruneep
    push it back to normal position then pull it hard < oh err >
    therevokid
    they can be a real pain sometimes … my slx is a bastard to get through
    the drive side bearing.
    found that gt85 sprayed on the axle helps, but still need to “assist”
    with a dead blow mallet !
    theotherjonv
    Mine always needs a bit of coercion with a few gentle tabs using a socket extension as a drift
    ajt123
    Do you put the socket extension inside the bb shell and tap through?
    ajt123
    Despondent. Don’t seem to be able to get it to go through.
    Superficial
    You’re not being persuasive enough…
    EDIT: Surely now you could whip the DS cup out and then you’ll be able to inspect it more closely to see what the problem is? +/- get the whole lot into a vise.
    nickdavies
    Rubber mallet. Most used tool in my toolbox.. 😉 hit it harder!
    You need to give it some oomph sometimes, the weight of the mallet head will have a lot more force than a spanner. Sometimes they do need some effort. Plenty of grease on refitting.
    theotherjonv
    Yes. Lip of the extension ‘bar’ against the edge of the axle and one big tap with the trusty camping mallet.
    Put it this way. It went through the other cup OK, so I’d assume it’s not massively ovalised.
    I suspect that if you whack it the worst that’ll happen is the plastic top hat will come out with it, and you might need a new BB. So unless you’ve got something irresistably bling in there, what’s the issue. What BB is it?
    ajt123
    Simon and the good folks at Nirvana cycles managed to sort it in the end.
    The solution was to really whack it with a rubber hammer whilst rotating the cranks.
    And I didn’t get charged! #LBSLoyalty
The topic ‘Hollow-tech II seized drive side’ is closed to new replies.
