Honest I know the On One Inbred 29er frame was cheap but serious! I am astounded and flabbergasted at how poor and how little time must have gone into choosing the cable routing on this thing 🙁
Let me start by saying I love how the thing handles and looks, and you can’t know the price.
Ok so it is the swapout version so can be used as a SS or with gears. I’m guessing they designed this for SS only and then suddenly decided to throw on some cable stops.
Not only do the cable stops on for the gears and brakes look terrible when cable fitted. For instance to have the gear levers on the correct side the inner cables need to cross under the downtube, which in turn snaggs on the bizzarly situated brake hose point.
Talking of the brake cable routing, if you use the lower mounts the cable twists between the stops on the downtube as two are on the outer edge and the middle one us under the downtube?! Madness lol
Anyway I have come to terms with this as like I say I know these frames are cheap so I am guessing we need to put up with small problems? so we?
The biggest problem for me is, the front mech cable routing. It is a under the bottom bracket type, so a bottom pull front mech is needed.
I tried a low mount one, but the clearance was poor so I put a high mount one on and I am shocked at the clearance lol Take a look at the pics below!
Anyway the tyre is a Bontrager 2.2 width and not a fat tyre.
If only the front mech cable routing was a top pull set up I could cut the unneeded arm of the front mech off, giving loads of clearance!
Such poor design guys, really disappointed…… The thing that makes me laugh more is that just after I bought this, I notice they changed the cable routing! So I guess it’s an admission that the design was bad? If only I could swap this one for the slightly newer version I would be loving this frame.
Sorry the reason for the post was to ask others in this situation, how they overcome this? and don’t just say “go SS” I would but we live in a hilly area and I like my knees in one piece.
Lots of front mechs are lower profile than the one pictured and will have greater clearance, its not a design fault of the frame, most 29ers are tight in that area.
I took the same route on my original Scandal 29er as Stoner but my frame is top pull. I have the same front dérailleur as you by the looks of it (older XT).
Going to need to find one with bottom pull and no gubbins sticking out of the back as I don’t like the roller method mentioned above. Too much faff and messy looking.
I would rather fit a clamp on cable stop and run the cable from the top, thus solving the poor routing and cross over below if you want to have your cables wrapping round the front of the headtube as most of us do.
On my Scandal I gave up and mounted the cables so they don’t cross over round the front of the head tube. I hate it and it rubs on the frame but it was the neatest way in the end as my inners where a bit too short.
At the moment I am running it as is with a skinny Continental rear tyre.
The cables do cross ynder the downtube as suggested, that’s fine but the daft boss for the brake cable is in the way and already wearing the paint off.
Oh well not to worry it was just a stop gap frame anyway, so no harm no foul I guess. Just dissapoined in poor cable route choices.
