Partner had a nasty off on Sunday, loosing the front (on a hardpacked manmade section of the HtN course, just after the second rocky short cut, if anyone knows the area).
Talking about it later, we realised that this is the fourth time in about six months this has happened to her, and the problem has only occured after fitting a LUST 2.35 HR, which is usually run with a tube at about 35psi.
Previously to this she's used Cinders and Fire XC's at the same pressure without any problems.
I've tried the tyre myself on the front over the last couple of days and it does feel a bit sketchy when leant over on harder ground, certainly not as grippy as the Ignitor 2.35 or Advantage 2.1 that I've used recently.
It the pressure too high?, I've tried dropping it but am unsure about how low I can go without issues.
I know loads of people rave about these tyres – maybe we just don't corner aggressively enough for them to work properly?
Anyone else had this problem?
Used for mostly XC on a 100mm hardtail, if this makes any difference.
