Rich (in the unlikely event that you’re still following this) the problem is that only treble comes out of the left speaker whether it’s plugged into the right or left on the amp.
I’m going to try some completely different cable next as it’s the only thing I haven’t swapped out.
I am still here, **** knows why!
The trick to this is to be totally methodical and change one thing at a time.
So with biwiring, you’ve got a +/- coming out of the amp. The cable splits into a +/- for the tweeter, and a +/- for the woofer.
Next steps for me would be:
If you’ve got a multimeter, buzz between amp ends and woofer ends of cable. – and + should not buzz to each other, but – to – and + to + should.
If – and + were shorted, I would expect the treble to not work as well.
Alternatively;
1.Play music, confirm no bass from left speaker. Mute amp.
2. At speaker end, swap tweeter and woofer connections. Unmute amp.
If you’ve now got no treble but you’ve got bass, then it’s definitely the cable. More likely to fail at the connector (if you’re on banana plugs), can you unscrew/remove the cover and take a look?
