Cp the stuff on the chainstay is called frame wrap i think and is like a rubber that sticks to itself, not bling but a very good solution.
http://www.biketart.com/products/framewrap
I noticed a solution for leaking pipes in Betterware that looks similar!
As for the mech knocking, very distracting, so i have used more frame wrap around the mech as after glueing the shimano one in place the chainstay ate through it in a couple of rides..
I've yet to use the longer rocker as i bought the bike because of the 100/160 thang.
I don't use any floodgate at all and there is no undue bobbing and the Pearl seems to take big hits/drops very well.
As for climbing, i run a Summer with 140 Vans so climbing on either is fine. If i want to drop the forks to make my life easy (Hemlock) then i can but slack angles just require a bit more effort (especially if your starting off on something steep). Its worth it when you get to the top..
Questions 1. if i put a shadow mech or Sram to stop the knocking, would i have to change to a longer cable if i wanted to put on the longer rocker?
2. My bike has the Pearl shock 08, has anybody ridden this bike with both the Pearl and Fox, worth upgrading?
3. Have you noticed that everybody who has a Hemlock has a 456 or Summer…
