Don’t forget that, as the bucket is full of fermenting homebrew, it’ll generate its own heat
Aye. Mine is kept in a temp controlled chamber, but you’ve got the gist of my OP 🙂
Basically, there’s a number who suggest that in the absence of proper temp control, you’re better pitching cool so as to mitigate the effects of the exothermic fermentation. ie, if your room is 20 degrees, pitch at 16 (despite most yeast manufacturers recommending pitching at 20ish).
It doesn’t make sense to me to pitch cool, since there’s a lag until fermentation kicks in, so surely the temp of the wort will have risen to almost room temp anyway before it starts? So it’s irrelevant whether you pitch at 16 or 20, the wort will be pretty much the same temp by the time active fermentation starts?
You left out a pile of variables which makes the calculations impossible.
If I knew what variables would be needed, I’m sure I could have worked it out myself with a bit of help from google 🙂
