Clearly it’s rising damp and you’ll need that snake-oil stuff injected into your walls 😉
UrbanHiker – Member
condensation?
[video]https://www.youtube.com/watch?v=CQGW46B6x_4[/video]
Condensation together with single brick exterior walls that are cold accounts for a lot of damp. Have it in my house on the most exposed wall. It’s simply because it gets wet and cold.
However, as said, seems unlikely if the carpet is soaking plus the walls are seemingly dry. More likely a leak. Under floor pipe? Is there any rust/hole under the radiator or behind where it might be dripping?
