Just getting my new Mojo ready for its first proper ride in the Lakes tomorrow and thought I’d have a look to see if the p1ss poor braking is due to the pads being worn (it’s done about 70km so I doubt it).
Whilst fiddling with the pads I noticed that the rear disk is rattling, and fairly loose. I took the wheel off and had a look at the mechanism. There appears to be a lock ring about 5cm or so in diameter with loads of indentations in it that look similar to what you get on a bottom bracket.
Should it be possible to remove this ring by hand? I’m guessing not since it says 40Nm on it or something similar and my hands aren’t that strong. So I removed it and the disk slid off from the pins that it was interlocked with. The pins themselves seem to be mounted on a similar 5cm diameter ring which itself binds onto the hub by a set of teeth on the inner side.
Two questions: Should the disk have a certain amount of play in it, ie rattle?
SHould it be possible to undo the lockring by hand? And if not, what tool do I need to tighten it up.
I appreciate that GIMF and I’m just about to look there but I thought I’d post beforehand just in case I can’t find the answer.
