Due to a long series of cock-ups I am having to fit a German regulator to the ‘van so I can use a German gas bottle. Of course, their fittings are all different. The chap in the shop sold me a flexible hose to connect the regulator and the metal pipe for the plumbing, but it goes onto an 8mm pipe and mine look like 9mm.
However the original flexible hose was fixed onto its fitting with a jubilee clip so I reckon I can put the old UK fitting onto the German pipe. The old fitting clamped around a copper collar/olive thing on the pipe.
However whilst trying (unsuccessfully) to remove it to see if the German fitting would go on, I scratched it up and I peeled off the old PTFE tape. Now if I do it back up again, it leaks.
I have more PTFE tape – how good is this stuff at stopping leaks? Is there any way of guaranteeing that there are no leaks? I don’t seem to be able to find any gas plumbing supplies here at all, I suspect it’s only sold to registered tradesmen. Can I just put water on it and watch for bubbles or what?
And yes I know I should get someone to fix it properly but there simply is not time! I need to either fix it so it doesn’t leak and gas us in our sleep, or go without cooking and refrigeration.
