- This topic has 2 replies, 2 voices, and was last updated 7 years ago by fisha.
Help with a Word Macro
woodlikesbeerFree Member
I’m trying to get a macro to run through a Word document and extract all the acronyms. I’ve found a reasonable macro that does this. The only problem is that it adds the abbreviation list to a table in the document being scanned. I want it put it in a new word document. I’ve tried editing the code, but I’m an absolute beginner at this stuff. Can anyone help:
Sub AcronymExtract() Application.ScreenUpdating = False Dim RngDoc As Range, oTbl As Table, i As Long, j As Long Dim strAcr As String, strFnd As String, strDef As String strAcr = "," Set RngDoc = ActiveDocument.Range With ActiveDocument Set oTbl = .Tables(1) RngDoc.Start = oTbl.Range.End For i = 2 To oTbl.Rows.Count With oTbl.Cell(i, 2).Range strFnd = Left(.Text, Len(.Text) - 2) strAcr = strAcr & strFnd & "," End With Next With RngDoc With .Find .ClearFormatting .Replacement.ClearFormatting .Format = False .Forward = True .Text = "\([A-Z][A-Za-z0-9]@\)" .MatchWildcards = True .Execute End With Do While .Find.Found .Start = .Start + 1 .End = .End - 1 strFnd = .Text If InStr(strAcr, "," & strFnd & ",") = 0 Then strAcr = strAcr & strFnd & "," strDef = Trim(InputBox("New Term Found: " & strFnd & vbCr & _ "Add to definitions?" & vbCr & _ "If yes, type the definition.")) If strDef <> vbNullString Then With oTbl.Rows .Add .Last.Cells(1).Range.Text = strDef .Last.Cells(2).Range.Text = strFnd End With End If End If .Collapse wdCollapseEnd .Find.Execute Loop End With For i = oTbl.Rows.Count To 2 Step -1 With oTbl.Cell(i, 2).Range strFnd = Left(.Text, Len(.Text) - 2) End With Set RngDoc = ActiveDocument.Range With RngDoc With .Find .ClearFormatting .Replacement.ClearFormatting .Format = False .Forward = True .Text = strFnd .MatchWholeWord = True .MatchWildcards = False .MatchCase = True .Execute End With j = 0 Do While .Find.Found j = j + 1 .Collapse wdCollapseEnd .Find.Execute Loop End With If j = 0 Then oTbl.Rows(i).Delete Else oTbl.Cell(i, 3).Range.Text = j End If Next End With Set RngDoc = Nothing: Set oTbl = Nothing Application.ScreenUpdating = True End Sub
CougarFull MemberWhat I can help you with is making that text vaguely readable. I’ve edited your post for you.
fishaFree MemberI think the simplest method would be to let the macro create its table, then once complete, copy-paste that table into a new document, then go back and delete the one in the original.
In days gone by with older versions of office I would normally use the record macro button to do some of the steps I wanted. Once recorded, then I would look at the code it created and modify it to suit.
For example, It would be easy to record a new macro that records you doing the following:
selecting the created table and copying it to clipboard.
file -> new file
paste from clipboard into new file
return to original document
delete selected tableonce saved, the code will be daily straightforward / understandable and could be merged onto the end of the code that creates the table in the first place.
The topic ‘Help with a Word Macro’ is closed to new replies.
