Hi,
I think the heat is getting to me and I need some ideas please.
I run a 1×9 set-up on my hardtail and have just replaced my worn out shimano 32t ring with a new On One stainless singlering specific 32t ring.
The new ring has nice deep teeth that look like they will hold the chain well. The chain is a SRAM PC971 and the cassette is a 9sp SLX (both unchanged).
The problem is that my chain is now slack around the front of the new chain ring – the chain sits well on the teeth at the top and bottom of the ring but is loose around the front.
It kind of looks like the teeth don’t match the spacing of the chain so as a result there is a lot of noise when pedalling as the chain jumps with each turn of the cranks.
Hope this makes sense – I can post pics if that helps…
Can anyone give me some pointers for a fix please?
Cheers!
