Viewing 40 posts - 1 through 40 (of 44 total)
  • Help! Why can't I fit my brake to my frame!!???!
  • edward2000
    Please can someone tell me whats going wrong in the picture below and how to solve the problem? It’ a new frame and a new 40mm mounting adapter. The brake is meeting the rotor, so where I am pushing down in the picture, the caliper will not meet the mounting adapter. Also it looks like the caliper isn’t in the correct position anyway, judging by where the rotor is coming out out the back of the caliper.
    All the literature says a 40mm post adapter is the adapter I need for a 180mm rotor.
    What’s going on? It’s driving me mad!
    Thanks
    scotroutes
    Does it fit with the adapter on the other way around (arrow pointing to the front)? 😉
    bencooper
    Because you’ve got the adapter backwards 😉
    shifter
    Edit: yeah backwards!
    neilwheel
    As above, arrow points up.
    edward2000
    If the adapter is the other way round then it mover the caliper to the left, o much so that there is no way the pads will come into contact with the rotor. This made me think a 20mm adapter is required but I have been told they don’t exist any more
    bencooper
    What size rotor is it?
    Edit: didn’t read the post – I think 20mm is what you need for 180mm isn’t it?
    Longer bolts and washers?
    scotroutes
    Where are your CPS washers?
    wwaswas
    have you got a 185mm rotor and the caliper’s for a 180mm one?
    [as per ben re-read post]
    but don’t sram brakes have lots of washers and stuff?
    JonEdwards
    Given it’s an Avid brake – does it still need the Tri-and-align conical washers of yore?
    grenosteve
    That could be a front adapter….
    Edit: yep, avid should have cup and cone washers?
    akira
    Adapter upside down, no washers and it’s not an avid adapter so will foul the pads.
    scotroutes
    Depends on the frame. Some come with a 140mm rear and you need a +20mm adapter for a 160mm rotor
    edward2000
    The adapter can’t be upside down, that’s not possible, and it came from merlin I an avid box, so I don’t believe that.
    hatter
    Yes, but these generally go on the outside of the caliper so they wouldn’t affect the caliper’s position in this instance.
    scotroutes
    How do those washers do anything other than take up bolt length situated where they are?
    wwaswas
    that’s what I thought. shouldn’t there be at least one of those domed ones under the caliper as well?
    edward2000
    If the adapter is the other way round it looks like this
    nemesis
    I would also have suggested that the adaptor is back to front (arrow pointing in direction of wheel rotation) and that it’s missing the spherical washers.
    But this pic suggests maybe not
    shaggy
    what frame is it?
    scotroutes
    An Evil Uprising?
    Edit – and it comes 160mm as standard
    nemesis
    edward2000 – Member
    Which looks right for a 200mm rotor which is what I’d have expected to be the case with a +40 adapter. I thought most mtbs with PM rear were 160mm if no adapter was used (while for example, my CX frame is 140mm if I don’t use an adapter).
    hatter
    Hm, some frames are spaced to a ‘direct mount’ for larger rotors. So they’re spaced for 160mm instead of 140mm.
    I suspect this is what’s happened here, you’ve got a frame spaced for 160 and added a + 40mm which has taken it up to 200mm spacing. which is why, with the adaptor the correct way up, the Caliper is sitting roughly 10mm too far out.
    What model & year frame is it?
    *EDIT* Yup looks like you need a +20 not a +40 adapter.
    shaggy
    They don’t use the CPS/tri align on the new Avid brakes. So my vote is with the +20mm adapter option.
    edward2000
    So where can I het a 20mm adapter from? I rang sram and they said they don’t do a 20mm adapter
    daver27
    Its a front adapter…. someone else mentioned it above
    scotroutes
    You could try one from another manufacturer but I think the caliper fouls them, hence AVID not doing one?
    Why not stick a 160mm rotor on?
    dirtydog
    CPS washers are needed between caliper and mount as stated in instructions, this depends on whether you have in line or offset tabs, think you might have to read the instructions.
    IA
    Use a 160 disk and no adapter? Which will be fine.
    wwaswas
    This from their instructions says use a +20 adapter.
    dirtydog
    Thats ^ kin ridiculous, could they have made it any more complicated?
    Think you need to work out whether you have inline or offset tabs.
    shaggy
    00.5318.008.003 seems to be the Avid part number for the spacer kit you need.
    nickdavies
    You can’t get a 20mm adaptor off the shelf for avids, it’s OEM only. Officialy you need the spacer kit.
    I was going to PSA this the other day – the adapter you need is here: http://www.on-one.co.uk/i/q/BSAVPPBM/avid-post-to-post-brake-adaptor
    Normally you can’t get them but On One must have bought a load for a build kit. £1.99 each I bought a handful! You will also need longer bolts, so the original spacer kit here will give you those: http://www.chainreactioncycles.com/avid-disc-brake-spacer-set-hardware/rp-prod108156
    You could just use the spacer kit but it’s a bit messy.
    I can confirm the on one spacer definitely works – ignore the picture it’s not that one you get. I also have X0 trails.
    davewalsh
    I’ll never understand the bike industry’s obsession with using oddball bolt lengths, non-parallel adaptors and those hideous CPS washers.
    OP, you have the wrong size adaptor and it’s fitted the wrong way round. Buy a superstar type 7 adaptor (180mm PM-PM) for a fiver and use that.
    http://www.superstarcomponents.com/en/disc-brake-adaptor.htm
    andyl
    In typical on one fashion the photo shows an IS to post mount adapter 😀
    nickdavies
    Won’t fit. That was what I did first!
    That is all they do…. SRAM haven’t released that adaptor to the public so if you use the recommended bolts they are too long! Totally half arsed for what you think would be quite a common requirement?
    edward2000
    Ok thanks for everyone’s help. I’ve brought a 160mm rotor. Can’t understand why sram would advise a 20mm adapter and not offer them for sale!
    davewalsh
    Nick, out of curiosity, why didn’t it fit? Did the caliper foul the adaptor?
    neilwheel
    OP if you still want to run the 180 disc these might work for you?
    It seems to be the 20S spacer kit that wwaswas posted earlier.
    edward2000
    Thanks Neil
The topic ‘Help! Why can't I fit my brake to my frame!!???!’ is closed to new replies.
