Help - which starte...
[Closed] Help - which starter FS
[#3733691]
Hi
I have a hardtail specialized myka at the mo but about to buy my first FS. On the budget I have and what I will be using it for (woods, trail parks etc , not going to be doing any jumps) I have narrowed down to two bikes the Giant Anthem x4 2011 and the specialized camber elite 2011 being a typical girl I just can't decided which one to go for! help!!
Posted : 02/03/2012 4:43 pm
What's wrong with your Myka? Why do you need a FS?
Posted : 02/03/2012 4:44 pm
It is a low spec and has been used and abused, needs upgrading brakes etc so decided it was time for a new bike, also have a womans specific and feel after trying other bikes that it doesn't fit right, I don't need a FS but I would like one I have tried out my partners bike and the difference over the lumps and bumps is amazing! 🙂
Posted : 02/03/2012 4:59 pm
It's a tough call - both are extremely good bikes and I can't tell you which to go for. I have an FSR myself (an old Enduro) and it's a much loved bike so on those grounds I'd probably opt for a Camber if my old Spesh died tomorrow...
...but the smart choice would be to see if you can borrow test bikes for a decent off road ride. I suspect that the Giant pedals better, bobs less and will give you more options if you want to upgrade the fork in the future.
Posted : 02/03/2012 5:07 pm
 flow
Anthem, no contest.
Posted : 02/03/2012 5:11 pm
What size frame are you after? Last year I did the same jump, and was undecided between a Spesh camber, ghost AMR 5900, and a cannondale rz120-2. Rode them all, all very similar, and I plumped for the 'Dale. I'm about to sell it to move up to an all mountain trail bike. Probably going to be looking for about £900 including Fox fork/shock and lots of carbon upgrades!!
Oops!! Forgot to say its a medium!!
Posted : 02/03/2012 5:18 pm
Is there anywhere near you that you can demo them both? You'll probably find within a few minutes of riding each one, which one suits you the best.
I did this when getting my last bike; it was between the 2010 Stumpjumper FSR & the Fuel EX8.
The Stumpjumper felt right straight away, whereas the EX8 just didn't suit me at all.
Looking at the two bikes - they are quite closely matched, although the Giant does come with Fox suspension instead of Rock Shox on the Specialized. Whether this is a good thing or a bad thing, is open to debate but Fox suspension is generally considered to perform a bit better, but has a reputation for needed copious amounts of care to avoid premature wear.
Apart from that, they are much of a muchness in terms of spec.
Geometry-wise, the Anthem looks quite a bit steeper than the Camber in terms of head angle. I am not sure whether this has any real impact when actually riding it, but suggests it will be a bit twitchier than the Camber.
Posted : 02/03/2012 5:19 pm
