So,
A few nights ago, I was woken by a dripping sound. Long story short, it was pouring down outside an water was coming in at a fast drip at the top of my bedroom window, where the horizontal wooden liner meets the UPVC frame. As a quick fix, I chucked a couple of towels down to soak up the leak.
I’ve had a look at it in daylight and I can’t immediately see a cause. There’s no slates loose as far as I can see, no cracks or anything visible, no gaps in the sealant outside.
How do I go about fixing this? Will something as simple as a bead of silicone be sufficient, or is it likely to be something ‘bigger’ that I need to worry about?
Ideas?
