Help - spokes quest...
[Closed] Help - spokes question
[#3914785]
Quick question. I have XT hubs and Mavic rims. I assume I can use standard spokes as having done a bit of googling it appears XT wheel sets use some exotic and hard to source spokes.
Is it the rim that dictates the spoke?
Posted : 26/04/2012 11:18 am
"standard" hubs and rims...yes.
Spoke length depends on rim, no of spokes, lacing pattern. Some hub flanges are different enough to the norm to have an effect, but not yours.
Posted : 26/04/2012 11:21 am
Thanks. I have snapped one – its not a full wheel build.
Everything else looks fine so I am hoping that I can just order some spokes and fix the one snapped one without to much hassle. I appreciate there are different lengths so I guess I just measure the one I snapped and maybe get some spares while I’m at it.
I have never messed with a wheel before - am I going to die?
Posted : 26/04/2012 11:29 am
lbs would be the best bet
Posted : 26/04/2012 11:30 am
lbs - you need to take the cassette off if it's the rear for starters.
It is essentially often a case of just tightening the spoke up, but there may be other issues causing the break, which an lbs may spot.
Posted : 26/04/2012 11:32 am
SJS Cycles sell spokes in small quantities, and the late great Sheldon Brown has a guide on wheel building and repairs (and indeed other pages on just about every other cycling related topic)on his website.
Posted : 26/04/2012 11:34 am
Thanks – the LBS it is then.
Posted : 26/04/2012 11:35 am
FYI - Just something to look out for.
Have you ever derailed your chain over the top of your biggest sprocket?
Many years ago I had repeated breakages on a back wheel. It was about the 4th replacement before the wheel builder noticed that a whole group of spokes behind the cassette were gouged. This happens if you over shift and is especially bad if the chain really jams down between cassette and spokes. Have a look, if they look a bit mangled it might be worth LBS replacing the whole group rather than doing the one at a time shuffle.
Posted : 26/04/2012 12:10 pm
Pretty sure the limiter is set bang on for the rear mech to stop that happening but it’s a good point and I will ask them to check them all out while its in.
Posted : 26/04/2012 12:17 pm
Update on this – the wheel has been in the LBS who have advised the failure is due to alloy nipples and there propensity to fail over time – my wheels are c4 years old. I wasn’t aware I had alloy nipples and the magnitude of how shit they are (discovered following google research). The LBS suggested a full rebuild with brass nipples but I thought that was a bit over the top at the time, pre consulting google.
So my wheel set has dodgy nipples. As I am likely to break more of these I think I should try and sort these out as they go.
What do I need to get in for the spares box / my bag. Brass nipples obviously, spoke tool ? spokes and how do you measure them to get the right one anyone know the lengths required on a XT hub / Mavic 717 combo? All help appreciated. 🙂
Posted : 02/05/2012 5:39 pm
Feasible - they may all be seized right now though!
Yup new nipples and spoke key. 262/264 for 32H I think.
Posted : 02/05/2012 5:41 pm
You know, building a wheel is not that difficult. Just needs a methodical approach. 😉
Just replace each spoke nipple, one at a time. Pluck another one on the same side & match the new nipple to that. Spot of oil on the thread, & nipple seat before putting the new nipple in. Might need a tweak overall afterwards. Me...I'd rebuild from scratch with new spokes.
Posted : 02/05/2012 7:09 pm
