I’ve a set up 2012 29er 140mm dual air revs and I struggle to get them feeling ‘just right’. Please excuse the lack of technical jargon, I’m a numpty.
I weigh about 90-95kg with kit on and find about 90-100psi in both bottom/top is about the correct pressure however, they are either too soft or too hard. Can’t find the ‘sweet spot’.
At the lower end of the psi scale they are very supple and perfect for the small stuff but, the big hits just blow through the travel. I also find at the end of the travel it just stops, now cushioning/slowing down.
At the higher end of the psi scale a little firmer, worse on the smaller bumps but better at the big stuff but, still the sudden stop at the top of the travel.
So, is it a case of either/or, what the hell do you expect from old forks? Is there something I can do? Stick more oil in the lowers, rub a mildly agitated shrew on the crown?
I know they can be ace as sometimes they just feel right. Really ‘plush’ and at the end of the travel a nice cushioning/spring that makes me smile.
I know I should play with the rebound but always forget and a little comfuddled which way to dial when I have more/less pressure in them.
Balls, I’ve no idea what I’m asking here.
