My husband’s just bought a lovely new frame (orange 5 – his first full suss) and since getting home from work has been excitedly stripping his HT and putting the bits on the new frame… Everything was going fine, but then he got to the fork and the steerer is too short! 👿
(He had left a couple of spacers in on his old frame but the difference between the Orange headtube and the 456 is massive)
Obviously very upsetting as the fork’s very new too (20mm bolt thru revelation)
It’s out by aboout 1cm (perhaps a m or two more – allowing a little space above when fitting). Is there anything we can do other than buy a new fork?!
We’ve looked at shorter stack height stems but I think we’d only gain 5mm there. Are headsets all much the same stack height wise? Obviously an integrated headset would be good, but I don’t think you can retro fit them?
I can’t think of a solution so thought it was worth asking here just in case…
My poor hubby has now given up putting the bike together and is sitting in the corner looking very depressed… 🙁
