Hi all,
Ford Focus Mk1 (V Reg, 1999/2000). Drove over a bump which caught underside of the car or something, steering wheel and passenger side dash airbags went off. No other damage to car (apart from cracked screen due to dash hitting it).
So, airbag warning light is on.
MOT is due 5th Aug. Anyone know the deal with MOTs and airbags? Someones said that the MOT doesnt actually check if the airbags are present (which they arent)/working, but just whether the light is on? And therefore if you disconnect the light its fine? If so, how hard is it to disconnect the airbag light?
Ford want just under £1k to replace both airbags (each bag is £430 + labour), which I cant really afford. Whats the deal with getting bags from a scrappy/ebay, and getting a garage to fit them? Dodgy (due to explosives etc)? I understand the module needs replacing or something too, is that something only a Ford garage can do?
e.g. Could I get one of these (even though I dont need the pretensioners) and get a garage to fit it/set it up?
http://cgi.ebay.co.uk/MK1-FORD-FOCUS-AIRBAG-MODULE-TENSIONERS-AIRBAGS-KIT-/250399895458?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a4cff2fa2#ht_2177wt_992
Anyone else has similar experience/problem?
Ta, Duane 🙂
