Viewing 9 posts - 1 through 9 (of 9 total)
  • Help please iMac running really slow on the net
  • Whyte1
    As above really it’s started to run super slow plus it’s breaking Internet connection when the iphone doesn’t , does anyone have a clue what’s wrong ????
    MrSmith
    Try applejack.
    Whyte1
    Is that an app
    MrSmith
    Is google broken too? 🙄
    zokes
    Last time I looked, it was part of the www – you know – the thing he’s struggling to connect to 😉
    Whyte1
    No that runs fine but slow as it on the Internet too
    MrSmith
    You have to download it too 😆
    Try a permissions repair.
    somafunk
    Do you have room left on your startup disk?, generally anything below 5% of the total size is substandard, empty your trash/secure empty trash as this will remove deeper hidden files in the trash and often helps to speed things up, you could also try a pram reset, i’ve cut and pasted the following procedure from another mac helpdesk
    You can also run a PRAM Reset, which which can refresh the firmware software of your processor and memory. Don’t recommend doing this all the time, however, if you are experiencing a lag in performance, this is a great procedure to implement.
    Here is the process:
    Here are some steps you can try to resolve the issue:
    • First, hold in your power button for approximately 10 seconds to do a hard shutdown.
    • Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
    • Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
    • Turn on the computer.
    • Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
    • Now, hold the keys down until the computer restarts and you hear the startup sound for the third time.
    • Release the keys and allow the Mac to start up. You should experience better performance of your Mac after running this procedure.
    Whatever you do please do not use a program called mackeeper under any circumstances, it’s a scam program that does ****-all good.
    Whyte1
    Thanks for that somafunk
The topic ‘Help please iMac running really slow on the net’ is closed to new replies.
