Hi ppl
I have just bought a 2011 Specialized S-Works Stumpjumper FSR carbon and want to put a top chain guide on it. I wont need a chain tensioner as I have the new Type 2 X0 rear mech with clutch so that will take care of chain tension. My problem is I do not know which mount to buy. Am I correct in that direct mount and e type are different fittings? I have looked on Specialized and they only did the frame only in S-Works guise for 2011 and therefore does not state which mount it is. If I look at 2012 it says S3 direct mount and the 2011 expert says S1 direct mount and my lbs said it was e type. Now I am super confused…
Do I need direct mount or e type, what’s the difference between S1, S2 and S3?
Any advice would be appreciated.
Craig
