Viewing 4 posts - 1 through 4 (of 4 total)
  • Help needed with hope hub
  • comcon23
    I’ve bought a set of second hand wheels with hope hubs, i think they are hope bulb? and I’m trying to convert the front into QR. I’ve bought(from crc) for hope pro 2 and when placed it makes the wheel too wide for forks.
    any ideas?
    Junkyard
    is it a hope pro 2 hub? If it is not you have the wrong part. Hope hubs say what they are on the hub under the logo Perhaps you have wrong size fitment? Is it a bulb/xc hub? Hope have Hope etched on them why are you unsure if it is a hope?
    takisawa2
    I always thought they were the same but according to Hope…
    Pro2 QR adapter is HUB419.
    Bulb QR adapter is HUB415.
    coatesy
    Just to be sure, measure the spoke circle diameter on the non-brake flange-Pro 11 is 54mm, Bulb is 47mm.If you have a Bulb then the converters you have won’t work, the correct ones for a Bulb are offset, and screw together to form an axle inside the hub.
The topic ‘Help needed with hope hub’ is closed to new replies.
