Untreated concrete blocks will let some water through in heavy rain. However pretty easy problem to solve:
– paint outside (I can recommend Suffolk Pink)
– waterproof coat in/outside (loads of options in builders merchants)
– Stick some thin outdoor grade ply on the in/outside
– Line the inside with DPC sheet (£35 for 50m roll of 1200g)
I get a small amount of damp creeping in at the base of the walls when it rains hard, as we’ve not painted the lower two courses of bricks yet, but I’m about to put down 100mm Celotex and a 1200g DPC over the floor with 18mm ply sheets on top, so I’ll never see it.
