if I put my weight on the pedal with the leading cranks arm at 2 o'clock.
it clicks once when you load it and once when you unload. doesn't seem to matter which chainring it's in – it's a certain amount of torque through the crank arms that causes it.
it's a Giant NRS. I've tried it with the shock 'deflated' and it does the same with the suspension bottomed out.
so far I have;
tried a different rear wheel
checked the ring bolts
checked the chain
taken the cranks out and checked the BB/reassembled
let all the air out of the shock and checked the suspension isn't noisy/creaky.
checked the suspension bolts are torqued up
I'm running out of ideas but the bike's unrideable (for me) – it's just so annoying that you get this click everytime you stand up on a hill or put some torque through it on the big ring.
