I currently have a prototype Northface Softshell bought for £5 from the northface outlet shop years ago. Its a thin but robust material and is very wind proof and doesn’t get sweaty, it doesn’t really offer any warmth and absolutely no water resistance (not sure it had any coatings when new). Its been used loads all year round in all weather and still looks as good as it did the day I bought it but unfortunately the zip is knackered so I’m looking for a replacement.
I have seen a few pics of gore ones I like but cant tell what the material will be like from the descriptions and the few on display locally are too thick.
The closest I think I may have found is the GORE FUSION CROSS 2.0 WINDSTOPPER ACTIVE SHELL CYCLING JACKET
I’m going to look at getting the zip replaced or fixed but still fancy a new one.
Regarding the zip, any idea what could be causing the problem? It first started a while ago when I got stuck in the the jacket when the zip wouldn’t undo. I managed eventually but it was very stiff. I put a bit of lube on the zip which helped but now when it closes it doesn’t sit flat it makes a v shape. it still works OK but I don’t know for how much longer.
Thanks
Andy
