50hrs a month!
OK, if your doing that your fit, so lets say 12mph is an easy off road average, 50*12 = 600miles. Including cake/energy gel stops, a few punctures and occasional chatting thats 2 hours a day, every day, 360 days a year!
p.s. Just because magra dont recomend services att he same intervals doesnt mean they shouldn’t be shown some love! I probably do mine every 50-100hours, only takes an hour tops to pop the lowers off, clean them out, soak foam rings, fill seals with R&R super slick, pop back together, add 15ml to each leg, re-assemble, pop top caps off, drain damper, refill damper, add 23ml to air piston (2007 forks need a bit more progression than standard IME), re-fit top caps, pump up with air.
Ohh and after this weekend I can recomend SS for Swinely, so go for soemthing with a firm motion controll/SPV/terralogic style damper, I’ve some old minute 100mm forks which are ace at this, despite beign shit in general at eveything else.
