OK, I’m finally getting around to fitting an E-13 DRS bash/chainguide I bought off the classifieds, I think it has a 40T bashring (though it may be a 44T as it covers my existing 44T outer ring?). My current chainset is XT setup with 44/32/22 rings (Hollowtech II cranks, so I guess this is a 104 BCD?). The cassette is a 34-11T SRAM jobbie
I’m thinking I’ll run a 36T and 26T up front to start with, how does that sound to you folk? I hardly ever use the granny (strong legs and I generally ‘grind/power’ my way up hills rather than spinning 😀 ). I prefer not to spin out (and I do a bit of road riding on this bike as well, would be nice to be able to sit on 30km/hr or so easily), so maybe I should stick a 38T on the front perhaps?
With chainrings, how do I know which ones will fit my cranks/spider? Do I just need a 4-bolt 104mm BCD outer and a 4 bolt 64mm BCD inner and all will be good? Are any particular brands better than others? What would you recommend? (thanks for the advice 😀 )
Also, the bash/guide didn’t come with the long chainring bolts (thanks to the chap I bought it off for mentioning this 👿 ), are these the right ones to get?
cheers folk, appreciate your help as always 8)
