Hey, I was cleaning my Saint (m810) caliper pistons with a little mineral brake fluid to rid them of the winter detritus and mistakenly overextended the amusing one of the pistons to pop out. I have managed to replace this within the caller housing, but now none of the pistons are extending when the lever is pulled. I am assuming this is due to air entering the calliper when the piston came out. My question is this: are the pistons designed to come out this way, if so how do you replace them? Will my brake resume normal service if I bleed the system, or have I broken them? Thanks for your help.
