hello chaps / chapettes – need a bit of advice about geo on some bikes i have ben looking at
Speech AWOL
Marin four corners
Genesis Vagabond
Kona Sutra
i am normally a 58cm TT and 200mm HT sort of guy i.e. 6’2 and inside leg 34
but a lot of the Large sizes i am looking at have a TT of 20+mm longer than i usually ride, i also appreciate the stems are shorter due to a more off road bias and therefore a more active front en but i need some help as to which sizes to opt for.
Genesis – looking at large 593mm TT but should i go for an XL with a 614mm TT ?
Marin – similar challenge – Medium has a 575 TT but the large has a 600m TT , but comes with a 70mm stem whereas i ride a 120mm stem for general gravel & road riding
any help appreciated
cheers
