I am in the last stages of my Production Privee Shan 917 bike build but have hit two problems. I have fitted a Hope 180 floating rotor on the rear but it is catching the IS mount adapter, I have tried both a Shimano and Hope IS mounts and they both catch. I have tried fitting my rear wheel off my FS with a 180 ice tech rotor and it fitted fine. The only way I can see how to fix this is to either file down a mm or so off the IS mount or maybe fit a washer/spacer to the QR.
The other problem I’m having is the bloody gears of all things! What ever I do I can’t seem to adjust the rear mech enough to go into first. I’ve adjusted the low screw all the way and it still isn’t enough to properly go into first.
Are both these related? It’s almost like the hub is 2mm too small. Shall I just fit a spacer to both sides of the QR?
Parts I’ve fitted – Hope rotor, Race Face Affect wheels and hubs and SRAM GX rear mech
