Can it be mounted on the frame using the handlebar mount too?
My tubes are too thick, the XL Handlebar Mount goes upto 33mm diameter. I’ve tried it on the seatpost and my leg hits it everytime.
And how did you get the route and speed etc in the video
I couldn’t get the GPS to lock on the ContourGPS, so I used my Edge to log the GPS Data. I’ve found one program to overlay the GPS Data on to the video called Dashware (it recognises ContourGPS data), they do a free trial too, I was so impressed I bought it.
There is also another web based app called BikeTelemetry that will output png’s for each frame or an .mp4. I have no idea how to use this with Premiere.
I was thinking of using 2 cameras
I have a little Muvi camera thing, I was thinking of taping it to my seat post and overlay it in the corner or something. I’m not sure how this would work as its a different frame rate and things. I think I need an idiots guide for Premiere.
Apparently (haven’t tried it), you can load your GPS data into Google Earth and then run the route in realtime and capture the video with screen capture software then overlay that into your video. Simples.. Apparently!
