Looking to protect some areas of a retro Marin mtb. Mainly want to protect the frame stickers from scratches – the paint is zelotone and is a matt finish.
If I applied the tape, and then remove it at a later date is it likely to pull the frame stickers off at the same time? The stickers are a little delicate and seem to be bonded on well but as I found out can slide off if pressure is applied to them!! They probably have some UV brittleness too.
So is the helicopter tapes glue likely to affect my stickers?
How long does helicopter tape likely to stay on the frame? Does it ever need replacing? or is it a once on , stay on affair?
Also would the tape look rubbish on a matt frame?
Thanks in adance
