I'm slightly surprised that if someone was walking around and at the skills circuit (which I assume means right next to Buzzards Nest Car park?) that it needed a helo; I'd certainly have expected to be bundled in the back of an ambulance if it were me. Of course there may be details we don't know which meant the crew on the ground or the operator on the phone believed this was sufficiently serious. If it genuinely needed a helo then ibuprofen wasn't going to do much and could only make matters worse - but sometimes after a crash a rest and the strongest over the counter pain killers are all you actually need to be able to limp back to the car and get yourself to hospital so I don't think it was the stupidest thing I've heard.
Borders General in Galashiels. TD6 9BS
That information is on all the trailhead markers at Glentress, along with "location" information for you to pass to the ambulance service so they can find your mates crumpled body.
However I am not first aid trained either...All you can do with some one who is seriously injured is make them as comfortable as possible
Well not really. Major blood loss in rural areas has the potential to be fatal so knowing how to deal with that is probably quite important. Most fractures are unlikely to be life changing but clearly spinal injuries could be - so understanding the difference between making someone comfortable and uncomfortable but stable might be worth knowing. Serious femoral (upper leg) fractures are also potentially life threatening if not stabilised due to the associated blood loss. Finally I'd guess that penetrating chest injuries etc are not out the question from high speed crashes into trees, bars etc. 99% of the time a little comfort, some help getting off the trail and getting to professional help will be all you need - but there are times a little bit of an idea what to do might just save a life.
