I had the same deal with a superlight (exact same bearing setup). I slowly nibbled away part of the out race with a dremmel until it was thin enough to stove in with a punch. Then hey presto, out the race came.
You do need to be very careful not to go into the frame. Fortunately the steel race sparks nicely and the aluminium frame doesn’t, so you have an indication if you go too far.
Other long shot is to pour boiling water (a full kettle at a time) carefully over the outside of the frame. The aim is to keep the race cool and the fame may expand just enough so you can get the race moving when punching it out from the opposite side. It is a long shot, but something you do tonight.
