Viewing 13 posts - 1 through 13 (of 13 total)
  • Heating alloy frame to help remove swingarm bearings
  • mrmoosehead
    So what’s the favoured method of heating?
    Blowtorch?
    Wife’s best hairdryer?
    neilwheel
    Gentle blowtorch or vicious hairdryer action.
    d45yth
    Boiling water, at least there’s no chance of damaging anything with it.
    vincienup
    Can’t just pop them out with bolt and washers?
    Conan257
    Personally I wouldn’t go anywhere near a heat-treated metal with more heat…
    My preference is to remove stuck bearing races with a dremel (other rotary tools available). It’s possible to grind out the race without damaging the frame.
    aracer
    You don’t go riding in the summer then?
    joefm
    Few degrees of sunlight is bit different to a blow torch operating at 400 deg plus. Hair dryer wouldnt produce enough heat.
    Come up with some sort of press/pull device from various bolts and sockets
    mrmoosehead
    They aren’t stuck, it’s just that the swingarm acts as the bearing housing, so the outer race is not visible on one side. So you have to drive/force the bearing out on the inner race, which has the chances of going horribly wrong.
    Was going to heat the frame a bit to make it slightly easier to get them out, whichever way I do it.
    Intrigued as to how to pull with bolt/nut – would need some kind of interesting brace that allowed the bearing to come towards it….
    Heath Robinson time I think.
    mrmoosehead
    Or just a really big socket, maybe.
    ndthornton
    Whats to go wrong – I imagine since your taking them out you have finished with them? your only going to damage the bearing as long as your Careful
    mrmoosehead
    One of them is really knackered – ball bearing popping out knackered. just hope that there is enough ‘bite’ on the other balls to bring the outer race with them.
    aracer
    As is boiling water.
    mrmoosehead
    Schweet. Came out simple on the link, now for the swingarm.
    https://www.dropbox.com/s/y87nljrppxkefh7/2014-06-30%2014.31.14.jpg
    Hmm. Supposed to be working…
The topic ‘Heating alloy frame to help remove swingarm bearings’ is closed to new replies.
