Viewing 13 posts - 1 through 13 (of 13 total)
  • Heat pump tumble dryer anyone?
  • tang
    Could be tumble dryer time here(there’s a back story too boring to type). What say you to these heat pump A rated things?? Anyone got one?
    GrahamS
    Yeah we do. Beko Dry&Save (DPU 8360 W) 8kg load, A rated.
    http://www.beko.co.uk/Item/DPU8360?col=&route=/BekoRange/Category-Laundry/Type-Tumble%20Dryers/
    I really rate it. Expensive up front but I did the sums and reckoned it would pay off the difference compared to a “normal” drier in two to three years.
    Good things: big load, large door, fairly quiet, knows how long it has to go, easy access to filters, little light inside, easy controls, time delay and anti-crease, outflow can easily be plumbed in to save emptying the water tank all the time.
    Bad things: dust/lint filters need emptying all the time.
    tang
    Thanks Graham, was looking at beko.
    sl2000
    Have had a Bosch one for a couple of years. Works fine. Takes a full machine’s washing. Haven’t had to clean any filters. Does weigh about 1 million kg though. Our builders carried it down to the cellar, and I’m not sure anyone will be able to get it out.
    GrahamS
    In a couple of years?? How? Where does the lint go? 😕
    The beko one has reminder lights to clean the filters but basically it is the pre-filter every couple of cycles and the main filter every six or so. Fortunately it is a very quick job as the pre-filter just lifts out and the main filter has a nice turn handle that makes you feel like you are installing a new CO2 scrubber on the space station 😀
    molgrips
    You always have to clear the filters all the time on tumble driers!
    oliverd1981
    When I was re-installing mine I found the air leak all around the back panel that had been filling the kitchen with grey dust. It’s now very much improved (gaffer tape)
    sharkbait
    Never heard of these – I’ll be paying attention as MrsSB does like to use the drier quite a lot!
    GrahamS
    It wasn’t so bad on our previous one which was an absolutely ancient tumble drier (e.g. controls were on or off). That one was vented and didn’t really have a filter so it just blew all the lint out the vent hose 😕
    But yeah I think most modern condensing driers you’ll have to empty the filter pretty regularly, so I’m intrigued by sl2000’s Bosch.
    sl2000
    Ahem – clearly it’s just my wife that uses it 😳
    So yes, it does have a lint filter in the door which you need to empty after every load. I’d forgotten about that in my excitement at it having a self-cleaning condensor.
    GrahamS
    LOL – aaaahhh so the lint is taken care of by the same laundry fairies that convert the smouldering heaps of minging cycling gear into fresh neatly folded kit in a drawer?
    Isn’t technology wonderful these days 😀
    cranberry
    Condenser driers = great
    Beko = make sure that you have a fire extinguisher and your insurance is up to date and you and your family are fire-proof.
The topic ‘Heat pump tumble dryer anyone?’ is closed to new replies.
