Hi All,
Need a little help, i’m a headset newbie, never replaced the headset cups on a bike before and I need to do it on the mrs bike. I’ve removed the old ones, but there are no size or markings to indicate the type.
She has a Commencal Meta AM3 Girly 2013, which according to the specs i’ve found is either a FSA Semi integrated Zero Stack tapered or Cane Creek ZS44 top, ZS56 bottom Tapered 1″ 1/8 / 1.5″
The fork is a Fox 32, with a straight steerer.
I’m looking to replace with a Hope Headset using the mix and match cups, she wants the purple ones. But here in Oz there aren’t any LBS stocking Hope so need to buy from UK and want to make sure the order is correct.
Once you’ve picked the top and bottom cup type and size do they come with the other parts like crown race etc..
Thanks in advance for any info
