I’m considering buying a Kinesis KM220L frame for my wife, the Kinesis website gives this advice on the headset:
“HEADSET: The KM220L uses a ‘ZeroStack’ headset for 50mm OD Head tube. The bearing cups must be press fitted into the frame and the bearings drop into these. [Headset not supplied].”
Am I correct that so long as I buy a 50mm OD (44 ID) headset of the correct steerer diameter it doesn’t need to be a zero stack?
I wants a slackish riding position and have a 20cm steerer tube which I don’t want to cut so anything lost from the stack height will have to be compensated for with extra spacers, which I’ll have to buy.
